Author Topic: 1272 T without BVH.....Worth it?  (Read 9331 times)
Offline AlexG40
« on: June 26, 2010, 10:55:09 am »
Basically I'm at the point where I'm seriously considering turboing the G. But I'm only running the standard engine at the moment. All my current power mods are bolt on. (Obv the cam and inlet will change as part of the conversion)
Question is am I pissing in the wind by not changing the head to a big valve jobbie when I do the conversion or will I still see a significant gain from where I am now with toothies and a flowed charger?
I don't want to do the conversion and then find that I should have gone for a BVH. But at the same time the BVH will significantly increase the cost of the conversion in the first place in which case I may just spunk all the cash on handling goodies and stick with the lader..
Offline cheys03
Re: 1272 T without BVH.....Worth it?
« Reply #1 on: June 26, 2010, 12:11:47 pm »
I'd personally be tempted to go with your suggestion of spending some cash on handling items. A PPP Stage 3 subframe would be lovely! By the sounds of it your setup is already putting out a sizable amount of power.
Offline Alexiskayak_7
« Reply #2 on: June 26, 2010, 12:39:01 pm »
Why not mate... You'll see a difference and you will gain more top end power that you don't have with the g..
If you have a healthy engine, you use gt inlet, larger tb, gt cam, g60 injectors a proper remap and you boost it up to 1,2-1,3bar you'll see aprox 170bhp with stock head...
Offline AlexG40
« Reply #3 on: June 26, 2010, 12:46:57 pm »
170 is not enough to be honest not for the sort of money we're talking about.
« Reply #4 on: June 26, 2010, 04:45:28 pm »
you can probably get 180bhp out of it with standard head.
« Reply #5 on: June 26, 2010, 07:54:30 pm »
That will be with 1,4-1,5 bar?
« Reply #6 on: June 26, 2010, 08:29:58 pm »
yeah something like that.
Offline Andy
« Reply #7 on: June 28, 2010, 09:07:56 pm »
You should be able to turbo convert fairly cheaply if you sell off the G-lader bits.
Think at least 180bhp is doable with 21psi of boost from a K03, probably more like 185bhp.
Offline AlexG40
« Reply #8 on: June 28, 2010, 10:00:20 pm »
180 would be about enough... I think you'll be pleased to hear though Andy that some PPP goodies are further up the shopping list at the moment!
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #9 on: July 01, 2010, 01:39:15 pm »
mines still running a stock head - 194bhp :-)
0.2bhp less than hayes :-(
Offline cheys03
« Reply #10 on: July 01, 2010, 02:05:05 pm »
Have you got a 1341 bottom end Robin? If so, what's the compression?
Offline Andy
« Reply #11 on: July 01, 2010, 05:42:37 pm »
9:1 CR on Robin's motor - he uses a stock G40 HG.
I run a stock head, 1341cc and 9.3:1 CR due to a thin metal HG. Need to remap mine on Emerald for high boost, but expecting 190bhp+.
Offline Insight G40
« Reply #12 on: April 02, 2011, 04:48:19 am »
It's well worth it with a stock head Alex. I've just fitted a T25 on an Emtec equal length manifold to mine and it's a lot quicker than my G, 166bhp and stripped out, ever was. This is in a car with back seats spare wheel and sub box in the boot.
I'm running pretty much the same setup James made 191bhp at Aldon with a few years back.
No idea what boost I'm running though.
Offline prankstar2003
« Reply #13 on: April 12, 2011, 03:52:48 pm »
Does the cam have to be changed for a turbo? Oc could you get away with a standard g40 cam for moderate boost levels?
Offline dub-disaster
« Reply #14 on: April 12, 2011, 05:06:04 pm »
Plenty of turbo cam info if you Use the search function. But main jist of it is when using a k03 you could do with a gt cam or a "turbo" spec one as otherwise the k03 will spool far to early and thus chocking up to early
