transmission gear linkage problem ????
Started by sohailG40, June 13, 2010, 10:43:43 PM
sohailG40
hi there i have a funny problem with my gear linkage (the part next to the gear box with the little rubber ball shape )
ok its fine when normal driveing but when i start to spank the g40 and do quick gear changes what happens is the little pin on the slecter rod which goes in to a hole on that ball unit keeps poping out and which is leveing me with no gears
ok i have changed all parts on the gearbox side of the sleter but the problem is still there
it only happens once in a blue moon like its happen 2 in the last 4 months
i was wondering has some one had the same problem if so what can i do to make it better
thanks for your time
sohailG40
dazzle53
happened to me and it turned out that my diff mount and top gearbox engine mounts where worn.
Try putting some Blue loctite on there that may help.
sohailG40
Quote from: dub-disaster on June 14, 2010, 01:30:55 PM
what part are you saying to put the loctite on ( the pin or the bolt )
sohailG40
nah the bolt is fine thats allways tight its the pin that keeps popping out
i guess i should check my gearbox mounts
