Vacum line
Started by đuro, August 07, 2008, 02:22:42 PM
đuro
Does anybody knows how long must be vacum line fm computer to engine. I read it must be 1 meter long but I don't know if this info. is correct.
Does anybody hs some information?
UndergrounD
This info is correct, it must be 1 meter long nog a inch less!
when it's shorter you can really feel it in the engine!
About two weeks ago i replaced this vacum line the new one
was 96cm long witch i replaces a day later for 1 meter.
The computer cant make good measurements with a vacumline shorter or longer
then 1 meter.
its not 1m - that is g60s - on etka it specifies 460mm - here the discussion took place    http://www.polog40.co.uk/forum/index.php?topic=292&start=0&#;post-1758
UndergrounD
Yeah your right, i was confused, the problem with the new vacumline
wasnt with my G40 but with the G60 i replaced the vacumline of both the cars
The new vacumline for the G40 was allready the right size, only the vacumline
for the G60 i had to cut myself with the result it was 4cm to short.
đuro
ok than I'll put 460 mm.
Tks for y. help
đuro
[quote pid=3190 author=Ä'uro date=1218435307]ok than I'll put 460 mm.
Tks for y. help[/quote]
I reduced wacum line on 460mm nd now there is no more inbalanced engine work. Before cutting engine worked betw. 980-1900 rpm., nd now works constantly on 950 rpm.
