little oil in boost pipe???
Started by Jake G 4 0, June 04, 2010, 04:32:44 PM
Jake G 4 0
Iv taken apart my boost pipes to rearrange the rocker cover and iv noticed some moisture in the pipe which seems to be oil.
Its not a great deal i was just wondering if this is normal or is there somthing i should be worried about or is this normal??
Any comments would be very appreiciated.
Many thanks jake.
AlexG40
Its normal.  Especially if the breather pipe is still attached to the boost pipes, i.e you haven't done the boost return mod.
If you have done the boost return mod then you may have some charger seal seepage, but if it's only a smear then I wouldn't worry about it.
Jake G 4 0
I havent got boost return mod, so it expalins the oil.
Many thanks jake.
