fresh charger build problems
Started by sohailG40, May 29, 2010, 11:25:27 PM
sohailG40
ok guys i just put the charger back on the car bit of a problem
idle very smooth but as soon as i get up to 3000 reves just before changing gear it get this nasty nosie like a bearing running with out the oil like a metal on metal nosie is this normal un till you runn it in or is some thing fucked and should i send it back
please all the help you guyz can give would be very gd
thanks for your time
sohailG40
cheddarcheese
you say new as in new charger 0 miles or a fresh rebuilt charger?
sohailG40
#2
no sorry its just come back from g werks after a full service
went in fine to them but when i got it back it sounds bad >:(
Daryl
Did they clean it? If they did i would send it back to have the bearings replaced same thing happend to a friend with his g60 charger. I will drop you a pm later to let you know the full story of it. All the crap they blasted his with got everywhere.
sohailG40
yeh they gave it a good clean dose that mean they might have left some bits of sand in there when they finished the sand blasting maybe i dont no
ill call them and see what they say tomarrow
thanks for your reply mate that was very helpful and i will look forward of reading the PM
thanks
sohailG40
