allen key
Started by g40Ross, May 28, 2010, 06:38:12 PM
g40Ross
hey guys
can anyone tell me what size the big allen key bolt is on the charger that allows you move it! as i dont have one that size im gonna have to go out any buy one or a set with it in!
cheers
Ross
Justin14100
The pivot alan key is 10mm.
However there is a 19mm bolt you need to undo to loosen / tension the charger. its behind / below the charger - the belts run either side of it.
g40Ross
nice one cheers for that mate!
g40Ross
im guessing you have to get at it from underneath the car?
cheers
Ross
Justin14100
no mate, shouldnt do - need to take the airbox off. get a torch on it and you should see it - behind the pully between the belts but above the alternator - best way i can explain it
