oil pressure sensors - where should I route them in a mk1 golf?
Started by g40willa, May 11, 2010, 12:19:12 PM
g40willa
Hi all,
I have the engine running, all good but i'm not sure where to route the yellow and blue temp sensor wires. I know that one should go to the dash for a warning light/buzzer but which one and where should the other one go? Many thanks all.
Also the sensor in the header tank has a brown and white/brown wire but i don't know where it goes in the dash.
The car runs and drives sweet but I want my gauges fitted before I drive it.
cheers, will.
the yellow/blue are a high pressure and low pressure oil sensors. not temp - both operate same buzzer.
header tank wires flash the water light.
g40willa
Yes sorry I meant oil pressure, trying to help a mate with a mk2 golf vr6, got temp sensors on the brain.
I thought they'd both go to the buzzer but can I wire them together and then to the buzzer? can't get my head around it and the Haynes manual has several diagrams.
also
I already have a wire from the black water temp sensor to my gauge, I asume the one in the header tank is for level/temp too? can i link that brown/white from the header tank to the same as the black water temp sensor?
Cheers pete
