Author Topic: Breaking in a charger?  (Read 2195 times)
Offline AdzCM
« on: May 04, 2010, 04:13:56 pm »
Just got a full blend charger off Gary on the forum. Its got all new bearings/seals etc.
Was wondering if anyone can advise me how to break/run it in?
Also, do I need to get a chip to run it or does the car adjust the fueling?
Cheers, Adrian
Offline Jezza-7
Re: Breaking in a charger?
« Reply #1 on: May 04, 2010, 05:11:26 pm »
Depends if what mods you have, like 65mm pulley, injectors etc.
If you have no mods but just the full blend charger then i dont think you would need a chip.
I beleive you should run it in by driving it for 300 miles off boost then do another 300 miles using a little boost but not flat out, then it should be beaded in. Not 100% sure but im sure someone will correct me.
Offline AdzCM
« Reply #2 on: May 05, 2010, 01:03:27 pm »
Cars standard atm, looking to break in the full blend before fitting a 65mm toothed kit etc.
Thanks James, thats sounds handy enough lol.
Anyone else know about if the car matches the fueling?
