dam wires
Started by hey pauley, May 03, 2010, 03:02:46 PM
hey pauley
Hi iam havin some real problems and wonderin if any one can help. I have a mk 2 with a g40 in and i have come to a stand still. The problem are. The fuel pump only powers when ignition is fully over to turn it over. The engine isnt sparkin. I think i have all the plugs in the rite place. Any advice would great or any one local that i could comper all to plugs to. The car is based in retford north notts.  thanks paul
the fuel pump should come on to prime for a second when the ignition is turned on but then it should only run fully when actually cranking the engine over.  As for there being no spark, have you got a spare ignition coil to try?  Is there 12v going to the coil?
hey pauley
ok thanks mate will try some stuff tonite and see what happens
pettsy
where abouts are you pauley?
hey pauley
iam in retford north notts mate
jake_smith
make sure its the black , green and brown plug into your coilpack
