Feeler for Black G40
Started by kaisegeberger, April 26, 2010, 10:33:59 PM
kaisegeberger
Had this H reg car for a few years and it inherited the good bits from a previous G40 I owned. Ownership has been trouble free apart from usual age related issues most of which have been sorted now. It has around 170000miles, but still uses little oil between services. Used regularly for work and did a 2000 mile round trip to the pyrenees last summer and a trip to Scotland involving a 50 mile drive with snow chains this Feb with no problems so I can vouch for the reliability in hot and cold weather!
Spec: Standard apart from.....  :D
Flowed charger (home brew, but copied Jabba R1 + a bit extra)
Ported head (Jabba)
65mm toothed pulley
GT inlet  (port matched)
Metal head gasket
Dewedged throttle body
Big filter and heatshield (Jabba)
Non-Standard coil
Catch tank
Boost return mod (designed so any oil spray is squirted at the exhaust rather than coating the engine bay!)
Stainless exhaust + decat (subtle, deep note and not too loud)
Injectors ('Green') + Chip to suit all the above (PSD)
Oil cooler
Larger master brake cylinder
Copper brake pipes
Braided flexible pipes
Subframe + Wishbones (PPP)
H&R Cup kit (shock+springs)
Boost gauge
Other New Parts (other than consumables):
Alternator
Starter
Aerial
Brake cylinders
Distributor
Gear stick gaitor :D
CD/Radio (El Cheapo)
Alarm/imobiliser
Body is sound with no major rust, but is a little tatty. I had new sills and part of floor done late last year so the painful work has been done.
This was built to be a sleeper and it really is. It looks like a bog standard Polo until closer inspection.
No proof of power, but it has the usual G characteristics. Piss-poor traction off the line (although this is now tolerable with the wishbones), blistering 2nd gear and it just keeps on after that! 0-100 is at least as quick as modern hot-hatches, but by-god its more of an event getting there! With the wishbone set up it handles like a go-kart too.
Really don't want to let it go, but need something more sensible (Scooby STi estate ;D) and don't have the storage space to keep it.
pm me offers. It should be available sometime this summer.
03harfij
hiya
what price are you looking for the car??
Jake G 4 0
#2
Hi there
I'm interested in your G and I was wondering if you would possible consider taking £1600ish at the end of may?? If not would you pm me to discuss a price you would let it go for.
Many thanks jake.
kaisegeberger
Car likely to be up for sale on ebay in the next week, after offers by other interested parties have been taken.
A few extra points for prospective buyers as its short on MOT (expires June 3rd, tax till end of May):
Has developed a leak from the brake fluid resevoir - should be cheap fix, brakes work fine.
One wheel is not balanced well (lost a weight?), slight judder at speed.
Slight play in tie rod - needs new ball joint.
Weepy unions on oil cooler - easy fix.
Boost gauge not included.
Fix those and it should fly through MOT mechanically (might only get advisorys for them). Emissions normally require a second attempt after the CO is trimmed down (its pre 1992 so has the non-CAT test).
dinger1991
hey, new to this thing lol. interested in car, u got any pics???
ereeiz
It says H reg but it's J on the pics? ???
kaisegeberger
Doh! Cock-up ::)
Definitely a J reg.
gti jack
intrested in this! could just give me a msg saying the offers your open to? i dont want to make an offer for it to offend you. be greatfull if you could get back to me
kaisegeberger
Up on ebay again.
Now with MOT and Tax. £1600 buy it now.
Max
