toothed pulleys guides
Started by dazzle53, April 02, 2010, 04:12:46 PM
dazzle53
where can i get pulley guides for my toothies? they are PSD phase 2
thanks
darren
scotsjohn
Only guides on the alternator pulley; yours should have them if phase 2. There should be threaded holes for them on the pulley.
dazzle53
got the holes but no guides   :(
you'll probably need to google search some gear engineering shops and speak to them.
are these some of the PSD rip off ones that juan made then?
youngprodigys
I have authentic PSD toothies I bought direct from steve when I bought my eaton stuff and mine never had the guides either. he said he would post them out - but it never happened.
I got a local laser cutter company to just make me up some circles to keep the belt on mate.
dazzle53
Quote from: hayesey on April 05, 2010, 02:28:25 PM
i didnt realise they were rip offs but they are from juan  :(
scotsjohn
Also, while you're getting things sorted, check the size of the slot in the alternator pulley. PSD ones have the wrong dimension for the Woodruff Key(at least mine have). They've cut it the same size as the charger pulley when it should be smaller. If yours has this problem then get the slot in the alternator pulley re-cut, the key slot in the alternator shaft opened out, or do a bit of shimming with strips of feeler guage.
