suspenion help
Started by rogersbmx, March 11, 2010, 07:45:03 PM
rogersbmx
i want to lower my G40, sites like venommotorsport have the kits i want but thy say excluding G40:/
i thought mk1 mk2 mk3 polo suspension was the same, anyone have any clues why this wud be, i dont wanna buy the suspension and it not fit!
cheeers guys.
they usually say -40mm, not g40 as g40 is -25mm (so effectively -15mm on a g40) they should all fit.
rogersbmx
oooowwww i seeeeeeee, coz there allready lower as standard, im with it now, cheeeeers :)
giorgio
its not an extra 15 mm. once you take the g40 susp off the car does not magically keep this -15mm
samg40
I'm sorry I dont understand that last comment?
giorgio
G40 Suspension is 15mm shorter than standard.
Putting standard suspension on a G40 will make it the same height as every other Mk3.
Therefore if you put aftermarket suspension on a G40 your car will be just as high/low as a Mk3 with the same suspension.
