Polo G40 1989
Started by PauloGT, March 09, 2010, 06:21:53 PM
PauloGT
Hello my name's is Paul, I live in french.
I speak not very good english.
So my polo is preparing for race in circuit.
  Made preparation :
Welded box
Kit wide body
engine block 77mm
Turbo K16
Customized mapping
injector 300cc
pictures :
SuperMario
Sweeet! ;) Ready for the circuit? or is that a future plan?
Puncharado
Looks like it's already been in a few rallys! :D
PauloGT
The box comes back from paint on matt black Monday in color.
The block is not in the car !!!! ;D
PauloGT
I find a camshaft for this motor can you help me please? ???
tdh-syorks
Schrick 264/260 i think
nice to see a beat up mk2 gt-g40 being saved!
Keep us updated with the progress.
thats correct rae - mk2's dont have the co pot though
Do they have a MAP sensor in the ECU still?  Wouldn't have thought so with an AFM
PauloGT
The MK2 have a " débimètre " (I can't translate this word)
The "débitmetre" is on the air box in color blue. The GT polo have this sytem.
The calculator haven't got  a map sensor.
mk2-limited
hi,your"debimetre" only runs up to 0,9 bar pressure!
if you gear up to a rs,g60,eaton you will need to swap to mk3 controller,map sensor.wiring,butterfly and airbox!
no idea how your turbo charger will work,but your contoller will automaticly run the fail-save program.
the old fashion way would be changing to an vauxhall-opel gte 16v "debimetre" wich will allow up to 1,1 bar if i remember.
that would be the chicken way out tho.....
could sent pics and partnrs if you like.
looks like a longer "shop season" for you.like your plan,keep mk2 g40 alive!
oh and i almost forgot...if you need some money to make your process happen.
i would be more then happy to take the pressure hose and g charger out of your hands!
Nick_S
Always good to see a G40 restoration :)  Reminds me of when Tom Garret found a similar state genuine 1987 mk2 G40 in the UK.
Is this the original engine? I thought all the mk2 G40's had bolt on water pipes and not the later push in fit type?
PauloGT
I not sure this is not a original engine, this engine was break with original valves.
MK2 LIMITED : I don't uderstand what you want ! ???
For this preparation I don't take the "debimetre" , I've MK3 ship  ;D
