My G40 has me a bit stumped at the minute
I had to take it for a 50 mile motorway run a while back, it was perfect the whole way until I got to the end of the motorway, as soon as I slowed down from motorway speeds the coolant light came on, I still had heating and the temperature was not unusually high, luckily I was as far as I needed to get so I was able to park up and leave it.
Two days later I had to do the return trip, so I topped the coolant up and set off, the exact same again, perfect the whole way until I slowed down at the end of the motorway, light on again.
I was a bit annoyed so just pulled it into the garage and have left it alone till now.
I gave it a good checking over tonight, the oil and water are not mixing and there are no bubbles coming up into the expansion tank with the engine running, I ran it for a while and everything seemed fine, nothing unusual from the exhaust, and no signs of leaks anywhere, but when it hit temperature and the fan kicked in a little bit of coolant came out of the expansion tank overflow
I'm not sure if this was just because the level was slightly over the max level as I know I had accidentally put a bit too much in or if this is where all the coolant has been going
Does anyone have any suggestions as to how to figure out where it has been going or what to check next?
Any suggestions really appreciated!
