polo gt coupe sunroof
Started by gjuro87, January 25, 2010, 08:55:10 PM
gjuro87
Hello to all!
Please, need help! I would like to replace rubber on sunroof edges, but I'm not sure how to pull it out. Do I have to remove whole ceiling or can I just slide it out through roof opening.
If any of you have experience on this topic help would be appreciated!
cheddarcheese
To remove the sunroof panel you have to remove the the sunroof rail and the panel together.
1. wind the sunroof open so you can get to the sun roof rail.
2.undo the screws witch attach the rial to the sunroof tray but leave a  screw each side of the sunroof winder area.
3.unclip the sunroof air flap thing to allow it to stay up (so it don't get in the way of step 4)
3. close the sunroof but not fully allow enough gap so you can still remove the last few sunroof rial fixing screws around the winder area that you left.
4. now from the inside remove the winder mechanism
you should now be able to remove the panel and rail together.
i think that's how it done but it don't take a rocket scientist to work it out from here!
gjuro87
