Author Topic: New  (Read 7490 times)
Offline Dirrt
  • #actlikealadythinklikeadirrt
New
« on: July 10, 2008, 11:26:32 am »
Hey ;)
My name's Laura, 24 from Malvern, Worcestershire
I have just bought this sexy bitch :wub:
[attachment=79]
I need to put her in for a service, any recommendations as to where/who I should go local to me?
Though I don’t mind traveling for it to be done right!
« Last Edit: July 10, 2008, 12:13:11 pm by Dirrt »
Offline DKnight
Re: New
« Reply #1 on: July 10, 2008, 11:43:02 am »
well hello
another female with a g40, whats going on!>!!!?
looks a nice motor, i remember seeing it for sale
as for a service, i would highly recommend doing it yourself, a service is only simple stuff really water oil etc, anyone can do it
What spec is it? service history? history on the charger?
welcome to the G40 world tho!
Offline Dirrt
Re: Re: New
« Reply #2 on: July 10, 2008, 11:59:13 am »
LOL
Thank you! :wub:
Always wanted one and now was the right time :P
This is all new to me being G40 virgin  >_<
I'm not completely retarded and am eager to learn my G inside and out, it's just learning it all
Oh, I'm talking bigger than all that! See my post on CP...
http://www.clubpolo.co.uk/forum/index.php?showtopic=114531
- Temp guage sits high (100ish) whilst running and only drops when I drive, but since it's been raining she sits where she should do?
Faulty temp sender or dash fault?
- Can't see any markings on charger to know if it has been serviced?
But from history there was a rebuild at 113K and there are Jabba receipts
- She needs oil which I'm doing today, but I'd like to the seal checked
- Battery light has flashed a few times on starting her
- Exhaust is rattling so I need to get that sorted
- Clutch seemed like it was slipping Monday night and the brakes are shit!
- Oh and the boot didn't lock, which I didn't find out till I got home so I had a mate of mine delock it for now
I don't know 100%, i only got the basics as the previous owner wasn't all that helpful to be honest with you
Re: Re: Re: New
« Reply #3 on: July 10, 2008, 12:00:27 pm »
oil filters - vw or mann ones (they have a valve in them)
spark plugs - ensure that they are bosch w5dpo (£10 each ish, but others some put in are not as good)
oil - semi synthetic oil
cambelts every 60,000 miles and change water pump at that interval
charger service - need doing after 70-80k then every 40k on a normal pulley, less on smaller ones.
welcome!!!! and enjoy!
Re: Re: Re: Re: New
« Reply #4 on: July 10, 2008, 12:04:34 pm »
[quote pid=2333 author=Dirrt date=1215687553]LOL
Thank you! :wub:
Faulty temp sender or dash fault?  can be a sender or dash or a rubbish thermostat
But from history there was a rebuild at 113K and there are Jabba receipts - that sok then
- She needs oil which I'm doing today, but I'd like to the seal checked - semi synth 10/40 is recommended (seal????)
- Battery light has flashed a few times on starting her  - normal i think
- Clutch seemed like it was slipping Monday night and the brakes are shit! - ahhhh mk3 polo brakes aren't the best
- Oh and the boot didn't lock, which I didn't find out till I got home so I had a mate of mine delock it for now - soak it liberally in 3in1 oil!!! might work then
I don't know 100%, i only got the basics as the previous owner wasn't all that helpful to be honest with you[/quote]
Offline Dirrt
Re: Re: Re: Re: Re: New
« Reply #5 on: July 10, 2008, 12:11:53 pm »
Thank you :)
Least I knew some off the stuff some off you have already said
That's a start  LOL
Offline wozzaG40
Re: Re: Re: Re: Re: Re: New
« Reply #6 on: July 10, 2008, 12:14:14 pm »
Couldn't hurt to give Jabba SPort a ring an see what work they have done on the car, they are usually pretty helpful an keep good records
Id get the battery checked out, and test the voltage of the alternator under load etc. good to get urself a multi meter.
http://www.polog40.co.uk/forum/index.php?topic=214
Read the above thread it is very useful!
Oh an good luck with the car.
« Last Edit: July 10, 2008, 12:26:14 pm by wozzaG40 »
Offline Raw
  • It ain't dubbin 'less her thighs are rubbin'
Re: Re: Re: Re: Re: Re: Re: New
« Reply #7 on: July 10, 2008, 12:27:33 pm »
I like the 'supercharged' decal on the doors, I've never seen that before.
Offline DKnight
Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #8 on: July 10, 2008, 12:44:38 pm »
Sounds like any other G, they do run quite high temperatures, in traffic especially, when moving air is flowing so engine will cool...
 best to get it serviced if in doubt!
Id do the filter too!
G40s always do this when you fire it up, tickle throttle and it goes away?
eays enough
check clutch to see if it is at end of its life, and G40 brakes are shit anyway lol, might need checking tho...
boot lock id take off and sit in some wd40 or something to loosen the internals
Offline jimbugalee
Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #9 on: July 10, 2008, 01:07:31 pm »
Hey Laura,  I am also 24 and a girly, although from down south in Buckinghamshire :)
I'm on my second G40 which I bought at the weekend.  Sounds like you are as excited as me to get started!
Nice looking Gee btw :)
Think these guys have helped you with pretty much everything so my advice to you would be to look after it, have fun and keep everyone updated on how you're getting on!
Gemma
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #10 on: July 10, 2008, 04:35:33 pm »
wow I didn't know this many girls owned g40s!
Welcome to the forum.
Offline DKnight
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #11 on: July 10, 2008, 05:24:48 pm »
sorry to do the usual expected bloke comment, but can we see some pictures :D
Offline G-spot
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #12 on: July 10, 2008, 05:25:01 pm »
Welcome on board, as for brakes I'd flush all the brake fluid out and bleed em up before spending too much on upgrades.
Offline cheddarcheese
  • i like boobs!
    • supercharged
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #13 on: July 10, 2008, 06:40:59 pm »
welcome!!! nice sexy bitch you got there!
Offline Dirrt
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New
« Reply #14 on: July 10, 2008, 07:16:00 pm »
Thanks for the welcomes and advice people LOL
I'll get some more pics up when i've got my plates on her :P
