I sold my car!
Started by Volkov, January 18, 2010, 04:21:12 PM
Volkov
I sold my car ... no more g40! :D
Nick_S
#1
Thats strange, Vagcat and ETKA list these for a 1985 Audi 90 with the following engine codes: CY,JL,JS,
HP,HV,KV,KX. (which i presume are 5 cylinder because KV and JS are) The part number is 853 615 125 from Audi. If i remember correctly, the distance between the mounting holes is 75mm, which is the same as your photo ???  The B3 Audi 90's changed the front brakes, possibly to 95mm like the mk2 golf 16v
If easier to find, the Scirocco GTX 16v also has the 853 615 125 front brake carriers.
genesisGT
the correct ones have:
"CN (then a number from 1-6) then  1515"  stamped on the curved part of the carrier.
they are usually fitted on the old GT Audis early version as the audis are fitted wit h2 different types depending on engine size adn what they had lying about in the factory. You can get them on german ebay alot but they are still about £100 a set. or you can make some spacer adaptors but personally i wouldnt trust them.
