inertia reel 3 point harnesses.
Started by GAF2, January 13, 2010, 06:49:25 PM
GAF2
have seen these used in a few cars but i cannot find anywhere to buy them, i know at least OMP and Safety Devices make them.  anyone know where i can buy them from.
cheers grant
tdh-syorks
i took mine out last year, with i kept them now, mine were sparco.
try here mate this should suit your needs
http://www.moss-europe.co.uk/Shop/ViewProducts.aspx?PlateIndexID=3930
GAF2
am i being stupid because i cant see any on that site either mate, but that 3 points look good and are a good price.
this is what am after: http://www.peugeotperformance.net/tuning/pdf/safety.pdf
Puncharado
I'm think I've seen them in a Demon Tweeks catalogue a while back, but can't see them in the latest ones, sorry this is no help!
I've never seen the point of them myself, the looks of a race harness without the function and the function of a seat belt without the practicality! If you like driving hard then they won't hold you in the seat like proper harnesses, but I do concede that you may be slightly better off if you do have a head on crash, you'll end up with two fucked shoulders instead of one fucked shoulder and a fucked chest! :D
jez1272gt
Another thing to consider with these is although there are fixing points for two of the mounts, there is no-where to mount the inside lap belt on the exhaust tunnel so you will need to have a eye bolt plate welded on to the exhaust tunnel to fix to. This should also be welded on the inside of the tunnel (exhaust side) and poke through a hole to the interior. It is basically a spreader plate and thread for the eye bolt in one!
