Author Topic: intercooler to charger hose- quick q  (Read 4765 times)
Offline batten
« on: January 10, 2010, 01:51:24 pm »
Hi guys, does anybody know the size/measurements for this pipe? the old one is shagged so could do with a silicone replacement, cheers
Offline LeonL
Offline batten
Re: intercooler to charger hose- quick q
« Reply #2 on: January 10, 2010, 02:46:18 pm »
thanks mate, ordered  :)
Offline Etches
  • Still got the G...
« Reply #3 on: January 10, 2010, 10:02:10 pm »
I am sure the metal fixing on my charger leads downwards for the pipe?
Offline Etches
« Reply #4 on: January 10, 2010, 10:10:14 pm »
Offline Etches
« Reply #5 on: January 11, 2010, 07:59:58 pm »
Bump does anyone have any pics or more info?
Offline Puncharado
« Reply #6 on: January 11, 2010, 09:22:41 pm »
Mines like this i think
Don't worry, there's nothing wrong with yours! Standard hose is the convoluted type, in rubber. The shape allows some engine movement relative to the charge air cooler, which is fixed to the chassis. The original rubber ones tend to split, and are not that cheap to replace. As it is for a specific application few silicon hose places make them, and they are even more expensive than VW. The silicon one above is a suitable replacement, instead of spending 70 quid on a proper convoluted silicon hose, such as this
http://www.g-laderseite.de/eshop/product_info.php?products_id=139
The other option is to cut down a metre length of wire reinforced flexible hose, this will be better at coping with high boost levels but will not be such a neat finish. Most of the slicon hose manufacturers will supply this.
Offline Etches
« Reply #7 on: January 11, 2010, 09:36:46 pm »
So those 45 deg bends actually fit with standard intercoolers then?
Offline Puncharado
« Reply #8 on: January 11, 2010, 09:46:42 pm »
http://www.polog40.co.uk/forum/index.php/topic,2538.0.html
It depends on you're pulley set up. I don't know if a bend like that will suit mine, I used a straight length but with an extra hose clip in the middle to stop it kinking. Not sure what I'll replace it with when I put the car back together though.
Offline Etches
Offline Jezza-7
« Reply #10 on: January 14, 2010, 06:05:13 pm »
So would the one from the g site be ok for a toothed setup?
As i beleive reading some where that with a smaller pulley the standard pipe wont fit as it is too short.
Offline Puncharado
« Reply #11 on: January 14, 2010, 06:43:09 pm »
Can't say about using it with toothed pulleys, I have neither!
I believe the standard rubber pipe was fine with mine and a 65mm pulley. So long ago though!
Offline Jezza-7
« Reply #12 on: January 14, 2010, 06:45:48 pm »
Hmm might just buy and try lol. Expensive way to do it though.
Will measure when it is done i think.
Offline Justin14100
« Reply #13 on: January 15, 2010, 09:16:08 am »
Mate on my custom toothies, i have a 45 degree bend and its fine for it buddy!
« Reply #14 on: January 15, 2010, 09:40:50 am »
i have a 45 degree bend on a stock pulley
