Digital Clock
Started by BrettG40, December 20, 2009, 03:29:56 PM
BrettG40
I realised the other day that some parts of the numbers are fading, is there anything you can do about this other than replace the whole clocks i suppose?
G40supercharged
I'm not sure if you can replace the digital clock on its own, but the speedo, rev counter, and fuel/temperature unit all come out separately. You should be able to swap your speedo (to keep the mileage) and rev counter into another unit.
supercharged spaniel
can't see why a cheeky little soldering iron couldnt sort this out like.  Soldering irons are cheap as owt and a bit solder too.  Un solder the old one and re solder a newer/undamaged one in?
