Author Topic: Leads andplugs  (Read 8339 times)
Offline Jezza-7
Leads andplugs
« on: December 07, 2009, 12:40:46 pm »
After replacing my thermostat housing i looked at the dizzy cap and rotary arm, man they were fuked. less than 1mm of copper on rotary arm.
Next is the leads and plugs. Now i have posted this somewhere before but i can remember.... :-\
What plugs and leads are good to go for?
Offline Jezza-7
Re: Leads andplugs
« Reply #1 on: December 07, 2009, 10:13:21 pm »
Has anyone got standard plug part number or where to get them from?
With the leads, i see some people use magnecor. Worth getting the 10mm ones or staying standard?
Offline breadman
Re: Leads andplugs
« Reply #2 on: December 07, 2009, 11:40:15 pm »
As Rae said, I'd stick with good quality German branded HT leads and Bosch plugs.
I can't see any reason to use Magnecor or any other so called "performance" leads.
Re: Leads andplugs
« Reply #3 on: December 08, 2009, 10:50:13 am »
plugs are Bosch W5DPO, GSF is the best place to get them from.  They will be replaced with WR5DPO at some point which is a resistor plug should be a drop in replacement.  Or the other option is the NGK equivalent B7EV-X.  Lots of people never used to like NGK plugs in G40s but I'm currently using them in mine at 194bhp and 21psi of boost with no issues.
Offline Jezza-7
Re: Leads andplugs
« Reply #4 on: December 08, 2009, 08:37:12 pm »
Any websites where i can look for them?
Offline Jezza-7
Re: Leads andplugs
« Reply #5 on: December 09, 2009, 05:37:40 pm »
Just looked on gsf, there asking £53.99 inlc vat and postage.
Euro car parts are asking £45.32 incl vat and free postage.
Just incase anyone else is buying some plugs soon.
Offline Jezza-7
Re: Leads andplugs
« Reply #7 on: December 09, 2009, 07:51:13 pm »
Also looking to get a new ignition coil, standard bosch one?
Re: Leads andplugs
« Reply #8 on: December 09, 2009, 10:57:36 pm »
Offline Jezza-7
Re: Leads andplugs
« Reply #9 on: December 11, 2009, 03:36:55 pm »
Would magnecor be ok to use?
Offline vwmk3jon
Re: Leads andplugs
« Reply #10 on: December 12, 2009, 09:00:10 pm »
think the plugs were £40.80 last time i got some.
Re: Leads andplugs
« Reply #11 on: December 13, 2009, 10:37:01 am »
yeah plugs were pretty much exactly £40 last time I bought W5DPOs from GSF.  I guess they'll probably have gone up now though due to the euro rate.
I wouldn't mess about with any leads other than OE ones.  Seriously, all the ignition components, use standard parts as a lot of the more expensive supposed "uprated" stuff is just shite painted fancy colours.
Offline Jezza-7
Re: Leads andplugs
« Reply #12 on: December 13, 2009, 12:25:49 pm »
Worth just getting bosch leads from VW then?
Re: Leads andplugs
« Reply #13 on: December 13, 2009, 12:39:36 pm »
well no, get them from GSF, they're not bosch made (neither are the ones from VW).  They'll be Beru or BBT.  Just ask for the "german made" ones.
Offline Jezza-7
Re: Leads andplugs
« Reply #14 on: December 13, 2009, 12:59:39 pm »
Ok, cheers!
