tool sizes - torque bits
Started by supercharged spaniel, November 22, 2009, 12:25:17 PM
What size spline or torque bits or whatever they are called do I need to crack the head bolts?  I have a spare 1.3 engine I want to take the head off to keep.  Also drive shafts?  What size. Im not going to bother with a whole set just gonna buy the two I need.  Thanks. Dan
drive shafts are 8mm spline and head bolts are 10mm spline if I remember correctly.  They're not torx.
no?  excellent thanks fro that hayz
86C
M12 spline key socket for the cylinder head bolts.
ah I stand corrected, 12mm for the head bolts!
Robin
for the head bolts make sure you buy a M12 tool which is a longer one rather than the stubby ones as one one of the headbolts will be almost inpossible to get to without a longer spline due to the head casting getting in the way.
gsf sell the draper tool which just has the two bits
pete
bbspolo
So do ecp if your nearer one of those!
