Author Topic: running rich  (Read 4220 times)
Offline GAF2
  • serious supercharging
running rich
« on: November 18, 2009, 08:18:13 pm »
hi guys, on a recent emissions test the reading on the g was 12%, so after reading a couple of posts on here i replaced the lambda sensor but when starting up you can still smell the petrol and the inside of the exhaust is blacked up.  Any ideas what to investigate next that could be causing this.
cheers grant
Offline lance
Re: running rich
« Reply #1 on: November 18, 2009, 08:29:24 pm »
check or change the blue temp sensor
Offline GAF2
Re: running rich
« Reply #2 on: November 18, 2009, 08:35:45 pm »
how do u check it? do u have to remove it?
cheers
Re: running rich
« Reply #3 on: November 18, 2009, 08:56:38 pm »
whats yr co pot set to?
Offline LeonL
Re: running rich
« Reply #4 on: November 18, 2009, 09:01:57 pm »
My car also seems to run abit lean,
How'd i go about checking the "Co Pot" pete? Mine seems to have been tampared with in the past due to missing blue cap and screwdriver marks in the black "cap?"
Offline GAF2
Re: running rich
« Reply #5 on: November 18, 2009, 09:17:27 pm »
sorry guys, your quite correct rae it is in the FAQ section.  Cheers guys am off to have a read and take notes.
cheers grant
Offline swiftg40
Re: running rich
« Reply #6 on: November 18, 2009, 09:29:47 pm »
have you got a de-cat pipe? emissions will be higher without a cat
Offline GAF2
Re: running rich
« Reply #7 on: November 18, 2009, 09:32:20 pm »
yeah its de-cated but thats not enough to cause this much overfueling
Re: running rich
« Reply #8 on: November 18, 2009, 09:34:53 pm »
get a multimeter over the two end pin of the plug
usually abotu 550 ohms
Offline GAF2
Re: running rich
« Reply #9 on: November 18, 2009, 09:50:40 pm »
yeah am goin to test that tomorrow and the blue temp sender.
cheers grant
Offline LeonL
Re: running rich
« Reply #10 on: November 19, 2009, 05:04:16 pm »
My Co2 Pot was 508 Ohms (think i done it correctly)...
So is this bad? Does this mean it is running richer then it should? How do i solve it?
Ps: Sorry for a little thread hijack, posted here since both have same problem
Offline LeonL
Re: running rich
« Reply #11 on: November 21, 2009, 11:49:28 am »
Anyone?
Re: running rich
« Reply #12 on: November 21, 2009, 07:10:56 pm »
you need to take it to a garage and put it on a gas analyser to set the co pot.  500ohms is a bit low though, I usually set it more like 600-650ohms as a base setting.
Offline LeonL
Re: running rich
« Reply #13 on: November 21, 2009, 07:52:42 pm »
Would this mean its running rich or lean? having low ohms on my pot
Re: running rich
« Reply #14 on: November 21, 2009, 08:43:34 pm »
lower means richer yes.
