Running lean
Started by G40 Tronster, November 16, 2009, 10:45:36 PM
G40 Tronster
Ive just had my head rebuilt after blowin the gasket. The guy who did the job said it was running lean before the head went. If i fit an FSA power boost valves as advised would this help it run better?
Cheers for any help Chris
Robin
no, get your injectors cleaned and checked and also change your fuel pump or at the very least check it over.
tbh its probably the eaton and it needs a remap
pete
yes it probably needs remapping.
