shagged engine for xmas great
Started by garye40, November 09, 2009, 10:29:35 PM
garye40
well just when I had built the eaton machine up seems i was screwed and me head gasket is gone also the head is badly damaged needs replaced
Also while I striped it i see that my bore is mirror like could explain that oil pissing out the dipstick,breather,exhaust lol
looking for ideas should i go 1308 or 1341cc i am ideally looking at an eaton with BVH all the usual mods maybe eaton cam if i ever get given the timing from someone
any thoughts
cheers in advance
Nick_S
#1
1307cc is a 1mm overbore and 1341cc is with a 2mm over bore. You are probably best going for the largest cc unless you are restricted by competition cylinder capacity thresholds?
garye40
so what else is needed for the bottom end then 1341 pistons 8:5:1 plus ?
Dirty Slag
A nice set of ACL bearings!
Metal headgasket
Forged pistons
Maybe balance your rods and crank!
Or just get some billet rods! (if available)
MEans you can run loads of boost and it wont blow up!
Obviously with supporting mods!
polo classic
No need to uprate G40 rods unless you want to go over 300 hp
Dirty Slag
Fair comment!
I just thought while it was in bits why not go the whole hog then you dont have to touch it all again once its back together!
hardchargin40
G40 rods are pretty strong.  I just had mine shot peened in my old engine.
garye40
Quote from: Dirty Slag on November 12, 2009, 11:36:37 AM
Metal headgasket
Forged pistons
thanks i have to get done in over here in North Irel so as you said I dont wanna be leaving stuff out but i do need to source a BVH too as mine is too bad for skimming and I might as well lol
matthg40
im quite concerned by this subject my head went about 2 months ago and i have an oil leak that i cant seem to trace.And what concerns me most is mines got oil spray on the back of the car from the exaust  :( :( sorry to hear about you car matey
vwmk3jon
I might be able to help with the details for the eaton camshaft, especially if you decide to go 1341.
matthg40
poloeatonm45
as far as im know the eaton cam is just set up to stock having said that i cant get mine to run at stock cause the valves touch the pistons lol been trying for over a year lol
steven
vwmk3jon
Would it help if i took my cam cover off and took a pic?
matthg40
aw mate that would be magic if you could do that  ;D
garye40
Quote from: vwmk3jon on November 19, 2009, 01:26:19 PM
well i have the cam never did get the info so anything would be great I had it in my last g40 but it ran bad had to take it out pending a day like this I have a local place that will rebore etc need to source some bits and give then clear instruction on what I actually want not sure I can afford cold forged do I have to use these for a 1341 ? Do kS do a cheaper set cause wosner are super expensive lol
