Brake bleeding nipples!
Started by LeonL, November 08, 2009, 07:16:22 PM
LeonL
Hi,
Replaced master cylinder today and bled brakes, however one of the brake bleed nipples is quite rounded so need a replacement ready for the next time i have to fiddle with the brakes.
I have standard G40 calipers, were can i purchase bleed nipples for it? Other then the scrapyard ;)
Leon
i can supply these for about £1.50 each - same thread either slightly shorter than stock with the 11mm spanner flat or similar length with a 10mm flat
pete
LeonL
I'll take 1 :)
Similar length one, also go check your injector sale topic ;)
SuperMario
you can get these from almost anyware!
vwmk3jon
Quote from: PeteG40 on November 08, 2009, 07:26:18 PM
pete
is that both front & back Pete?
back ones you can get from gsf - but they are nearly the price of a cylinder
Price for two short/11mm nipples plus postage please Pete ?
cheys03
Got some ATE ones from the dealer - £8 the pair admittedly  :o , but damn good quality made of decent steel instead of the cheese from GSF.
