[quote pid=1260 author=Da Hayz date=1210345630]
- inlet air temp and CO pot: to test the inlet air temp, use a similar method as above, also use the same guide values, again they aren't too accurate so expect some variations in the resistance readings but should be in the same ball park. For the CO pot, around 600-650ohms (measure across pins 2 and 3 if I remember correctly) is a good base setting, the car shouldn't be running bad like that. But you need to put it on a gas analyser to set properly at idle. [/quote]
I replied in the FAQ but its actually pins 1 and 3.
The real reason for the thread is the last line which is in Italics.
What does the CO Pot actually do and what am I supposed to be aiming for on a Gas Analyzer? Would different methods of Forced Induction require different resistance?
Mine was set at about 1100 Ohms. Would this have been set at a higher resistance as my car is on a base map?
