Urgent info about wheel bolts
Started by Jezza-7, November 03, 2009, 05:28:18 PM
Got 14" bbs ra's on now but my bolts aren't the same as they were when they were standard. Someone has changed them to Conical aka tapered ones for the OZ alloys that were on.
I think i need the radius ones.
What is the correct size and length of bolt that i require?
Need to know asap so i can get some on order.
Cheers!!!!
GAF2
I got 14inch bbs ra's and you need longer bolts for them i used these.
12MM X 1.5 LOOSE RADIUS BOLT 50MM LONG- got them from demon tweeks the 50mm was a bit too long for the back, was catchin in the drums i just cut 10mm off but you could prob use  40mm.
cheers grant
GAF2
you def need the longer bolt for the 14inch wheels something todo with the depth of the mounting face.
cheers grant
What make did you use. The grayston ones?
Got 50mm and 40mm grayston ones. Fit fine. Cheers for your help guys!
