Problems With a Mates G40
Started by Tony100, October 28, 2009, 02:55:13 AM
Tony100
Noooooooo its not mine this time!!! thank god!!!
my mates bought a standad g40 had it for bout 2 years naw........... the only mods are an air filter and a 65mm puley
For the last 2 years its seems to be spitting out oil when he gives it some welly!
He seems to get oil on his drivers side chassis leg? naw theres not many things it can come out of
Am i right in thinking its coming out of his dipstick???
What would cause it to spit out oil on the drvers side leg??
on the chassis leg it could be the charger pulley seal, crank pulley seal, cam pulley seal or dipstick -  a number of things to check.
Wipe it down properly then check again.
G40supercharged
The problem is the breather system is blocked up. This causes the crankcase to pressurise and forces oil out of the dipstick tube, particularly when on boost. You need to clean out the breather pod (metal dome at back of block) plus black plastic valve thing attached to this. It's possible it may have damaged various oil seals but I would sort the breather and then see if the leaks go away. I got my first G40 in 1999 for about half the book price because it had this problem; cost 15 quid for a new breather valve and has been fine ever since.
it COULD be the breather.. but i've rebuilt and engine with a clear breather but a disintegrating crank end plate gasket.
Yes the breather can cause seals to go, but its not the only cause.  Some seals are nearly 20 years old now!
Tony100
Ye thats a good idea?
so whats best for him to clean/replace??????????
Clean the breather pod?? which requires taking it off? which means taking the inlet manifold off?
vwmk3jon
Tony100
Ive just taken the inlet off his car naw!! im assuming you guys are on bout the round thing the the charger breather comes from?? ( goes through the rocker cover onto the throttle bodie and the tee's off down on to this vavle??
This thing just spins when u try and budge it?? how do you take it off?? and am i taking the right thing off?
Tony100
#7
This the valve you on aBOUT?? how do u test if its shagged?
which is attached to this??
What do  i do naw??
Tony100
how do i take the pod thing off the block?
it's just a press fit, need to prise it off with a flat screwdriver, just be careful not to damage it.  People normally bin the plastic one way valve and run a 1" bore pipe from the breather pod to a catch tank.
Tony100
Is it wise to run a catch tank some say its bad for the charger??
just need to run a pipe from the (pod) shaped metal thing on the block to a catch tank then get a charger blanking plate??
G40supercharged
You should be able to blow through the valve thing; it flows more air one way than the other. If it's blocked you could try cleaning it with carb cleaner or similar. I've always just bought a new one.
QuoteIs it wise to run a catch tank some say its bad for the charger??
you'll have to make your own mind up on that.  You'll prob find just as many people say it's bad as say it's better.  Personally I think it's better to use a catch tank and then spray the charger every 1k miles with a small amount of ptfe lube.  Where people seem to go wrong is either using the wrong type of PTFE spray or putting waaaaay too much of it in which just clogs the charger.  If done properly I think it's much better than lubricating the charger with the horrible crap that comes out of the oil breather.
Tony100
Whats the correct PTFE spray to buy?? and how much do you spray it?? at wot revs??
http://www.polog40.co.uk/merchandise.php
spray every 1k miles approx.  Just give it a couple of short sprays, rpm doesn't really matter, perhaps 1500, 2000... it's not rocket science, just don't unload half a can in there at once as some people seem to do!
