Yeah, I use the green spring in mine as I've got Emerald and an N75 valve for electronic boost control, so need a low 'base boost' setting. Tensioned up normally you'll get 7psi or so with a green spring, you'll need a bleed valve to hit 15psi with one I reckon!
