fitting standalone oil tank
Started by Jezza-7, October 07, 2009, 09:01:41 PM
That's what I'm using by the looks of it. All seems OK for me . The short life they're stating's more than likely for stresses in con-rod bearings knocking the shit out of it. Your charger's not got that problem; rollers/tapered rollers? don't have the same lube problems.
well they wont do because they are brake pipe unions so have holes through them.  Although I've used one of them filled with solder by heating it with a blow torch before.
Tommo
Im guessing you could just use a bolt with the correct thread and a copper washer?
Ok i will try find the right threaded bolt or try your idea. I think i might have some at work. Will take my thread gauge tomorrow.
yeah just any m10x1 bolt with a copper washer will be reet
