Author Topic: had my k03 and wow  (Read 4111 times)
Offline nikky
had my k03 and wow
« on: October 06, 2009, 01:13:13 pm »
just had my k03
 not very big is it :o
i was thinking it would be bigger but as alot use them and see good gains they must me good :-\
Re: had my k03 and wow
« Reply #1 on: October 06, 2009, 01:52:07 pm »
it's a small turbo yeah but it's only a small engine.  they can make 200bhp and 23psi boost.  They are also cheap to buy 2nd hand.
Offline nikky
« Reply #2 on: October 06, 2009, 03:15:55 pm »
very true!!
i got one now for £85 posted in very good cond ;D
just wait for the mani to be finshed then fit plumb it all on  ???
Offline VW_rae
« Reply #3 on: October 07, 2009, 06:44:12 pm »
can you run the boost without any issues???or is there other components needed???
Offline nikky
« Reply #4 on: October 07, 2009, 07:32:02 pm »
so far i got
oil cooler(thermo)
k03
forge actuator
custom manifold
gotta make my down pipe in 65mm steel
oil feed/drain
water feed/drain
frontmount and pipes
245cc/min at 3bar injectors
air/fuel meter
dumpvalve
turbo chip(till i can afford a remap)
2 3/4"exhaust system
was a right bugger to get the right water and oil feed fittings,,oil m12 1.5 thead water m14 1.5 thead
just waiting on my manifold then il start bolting it all on
ohh and i wana make some turbo brackets so its easy on the mani ::)
« Reply #5 on: October 07, 2009, 07:37:59 pm »
correct fuelling is the key, so you'll need a good remap.  Aquamist helps too, without that you'd probably have to retard timing to the point where you'd be better off running less boost and more advance.
