Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Turbochargers
fuel pumpsto suit turbo conversion
« previous
next »
Pages: [
1
Go Down
Author
Topic: fuel pumpsto suit turbo conversion (Read 4416 times)
Tommyk
will i ever finish the project!!!
on:
October 01, 2009, 03:05:34 pm »
as above, whats the best fuel pump set up to use with a turbo conversion?
i take it a fuel presure regulator is a necessity?
Tommy.
lance
Re: fuel pumpsto suit turbo conversion
Reply #1 on:
October 01, 2009, 03:13:04 pm »
just all standard is fine too 190bhp maybe more.
Administrators
The CV joint killer
Reply #2 on:
October 01, 2009, 03:55:15 pm »
no need to change either the pump or the regulator.
If you are aiming for 200bhp+ then swapping for a higher max flow rate pump might be worthwhile but you'd still not change the reg
Tommyk
Reply #3 on:
October 01, 2009, 03:57:16 pm »
i currently have a standard gt one at the mo as its a converstion, but im guessing they are lower pressure than G40 ones? but if not then that will be fine to use then? engine is set set up to be producing around 180hp
Last Edit: October 01, 2009, 04:40:41 pm by Tommyk
Administrators
The CV joint killer
Reply #4 on:
October 01, 2009, 05:14:20 pm »
GT fuel pump and pressure reg are the same as G40. I'd be wanting to replace the pump with a new one if it's like 15+ years old though.
Tommyk
Reply #5 on:
October 02, 2009, 09:13:00 am »
many thanks. god knows how old the fuel pump is! haha but will get a new one anyways though!
lance
Reply #6 on:
October 02, 2009, 04:08:14 pm »
be cheaper to upgrade the inline pump than buying another original from vw!
Dan
Reply #7 on:
October 02, 2009, 06:39:30 pm »
Euro car parts are a bit bit cheaper than VW. Euro is about £130 and VW are about £160
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Turbochargers
