Help with a few things
Started by Jezza-7, September 28, 2009, 01:26:30 PM
Have a few things on my mind...
Can someone tell me why oil catch tanks have two inlets?
And how to fit them?
What is the purpose of a standalone oil tank?
When using an oil cooler kit does the oil pump need to be replaced or get an uprgraded one?
Can someone tell me why oil catch tanks have two inlets? -normally one inlet and one outlet so it doesn't pressurise
to your breather pipe - remove the one way valve, like a flying saucer and fit a 1" pipe to catch tank - blank off the charger second inlet and use PTFE lube once every 1000 miles
To reduce the oil temp/pressure to the charger, increasing bearing and oil seal life
no - should be fine
