not having a good day, went to work yesterday morning car running fine, after work car running on 2 cylinders (1 and 2 not firing). managed to get her home and start checking things, took plugs out of 1 and 2 and they were wet, so i put other plugs in ,no change. replaced leads, no change, so i checked the dizzy seemed to be ok but changed that and arm today again no change. took a meter and checked the feeds to the injectors and they were all giving the same reading . checked the timing and that was fine, took the rocker off and nothing suspicious.
a list of things ave checked
plugs
leads(plenty of spark)
dizzy cap(replaced)
rotor arm(replaced)
timing
injectors and electrical feeds.
I find it funny that there was no problem on the way to work and then when started it up after work she was only firing on no 3 and 4.
has anyone got any idea of what it could be before i rip the head off (and probably my own)
