Author Topic: rebuild kits - £175 for a full kit  (Read 25096 times)
Offline Jezza-7
Re: rebuild kits - £185 for a full kit
« Reply #15 on: March 27, 2010, 07:08:14 pm »
only a couple of quid for the postage on bolts... full Kits cost about £6.50 to post insured
pete
Pete i will defently buy the bolts off you. I might as well replace the ones in my charger as its off at the mo.
Offline g40Ross
« Reply #16 on: May 30, 2010, 04:53:27 pm »
is a charger rebuild a simple job or does it require skills?
Ross
« Reply #17 on: May 30, 2010, 08:04:38 pm »
its not a ten min job, takes a few hours. Quite a few people have done them off here though
Offline Raw
« Reply #18 on: August 30, 2010, 06:58:25 pm »
Hi Pete,
Can you sell me a banjo bolt for the oil inlet? If not can you tell me where you get them from?
Cheers, Andy.
« Reply #19 on: August 31, 2010, 08:55:15 am »
i've got a few here mate yeah
Offline j.barnett
« Reply #20 on: October 06, 2010, 09:57:29 pm »
do you do a rebuild service?? maybe r1 spec???
« Reply #21 on: October 07, 2010, 08:17:58 am »
na - I rebuild the odd ones, but porting is too time consuming.
Offline Turbodaily
« Reply #22 on: November 19, 2010, 09:42:12 pm »
Just recently purchased a kit from pete, top seller! Nice one....
Offline xrrich
« Reply #23 on: November 19, 2010, 09:47:33 pm »
Also recieved my kit the other day from Pete, Great. Top guy
Offline bengim
« Reply #24 on: November 20, 2010, 02:32:54 pm »
I am thinking of having a go at this. My chager is weeping a bit of oil and although i was told its been serviced i don't believe it.  I'm not the most mechanically handed of people but i have a couple of weeks off over Xmas so seems a good time to try this. Where can i get a copy of the instructions so i can have a look and see if this is do-able for me? If i'm happy to have a crack then i'll order a kit. Also any advice on what else i should be doing other than replacing the bits would be much appreciated, ie. cleaning how/what to would be really useful.
apologise if these are very naive questions but i have no experience.
thanks in advance
Ben
« Reply #25 on: November 21, 2010, 11:55:28 pm »
pm me your email address and i'll send you one
Offline grungeisdead
« Reply #26 on: February 16, 2011, 06:02:26 pm »
ey up, got a set of seals, bearings and kluber grease in stock? dont think i need the apex seal strips the ones in the charger look ok
whats the damage maestro as i can get adam to pick up them on his travels to you at the weekend
« Reply #27 on: February 16, 2011, 07:44:43 pm »
look ok? looks can be deceptive! the limit between new and fecked is 0.2mm - so you need to use a vernier caliper to measure whether they are actually ok or not.  as new - lots of boooost, worn out, not so much boooost.
got all the bits in stock yeah. £45 for the seals, £65 for the bearings - kluber £5 so £115 altogether.
« Reply #28 on: February 16, 2011, 08:57:07 pm »
im a pikey lad, ill stick it together with fresh seals and bearings and see what happens, if its not boosting well, then ill replace the apex seals, no point replacing if they are fine and its easy enough to split the charger down to replace the seals.
saves spending money when its not absolutely neccessary! fair point about grabbing some verniers though, i did have a set but broke the screen (digis)
ill take a gates belt as well mush, and either give ads the dollar or come along for the trip.
cheers :)
« Reply #29 on: February 16, 2011, 09:02:26 pm »
bring the apex seals - i can measure them if you want.
though i've messaged ad - you might have to swing by dk's (15 min from me) to get the heavy shit as i'm not sure i'll have time to pick it up before sun.
pete
