Author Topic: rebuild kits - £175 for a full kit  (Read 25170 times)
Online PeteG40
« on: September 14, 2009, 10:51:45 am »
right, after some extensive research and now testing...   I can to supply rebuild kits for g40s and one off spares should people need them. Each part is the same as a g60 apart from the centre bearing
Viton oil seals - the same as a g-werks and psd chargers i recently serviced (size and make)
2x scroll £13 each  - £25 the pair
1x outlet side £5.00 each
1x inner pulley side - £7.50 each
1x outer pulley side - £7.50 each
full set £40
FAG bearings
2x countershaft bearings £5 each
Uprated SKF top bearings (low friction seals £10 each
1x pulley side main bearing £6.50
1x outlet side bearing (these are often not replaced as they can be hard to get out and they are a dear bearing) £43
1x IKO scroll bearing (IKO have been in PSD/Gwerks Chargers) £18
Full set of normal bearings £70, with uprated top bearings £80
Optibelt/Gates - as used originally - but 12mm wide timing belt £6
1x set of apex seals.  Remade for us in Sintimid beige compound as used by vw in the 1993 (the same company!) onwards supercharger. Beware of rolls of cheap stuff being sold on ebay - this is massproduced crapola.  These are cut to oem specs and are aperfect fit
 £65 a set
£175 - full set £185 with uprated top bearings (incl a set of casing bolts)
top scroll bearings - obsolete from FAG, but this is as supplied by max-rpm and bartek £42
for £3 can also supply a set of 12.9 zinc coated bolts for the casing
NOW i can supply bonding agent for the seals - as used on g-ladersiete.de./maxrpm - good stuff £7 for 10g
30g of kluber grease - brilliant stuff - charger needs to be apart to use though! £5
« Last Edit: October 23, 2013, 07:41:42 pm by PeteG40 »
Offline Justin14100
Re: rebuild kits
« Reply #1 on: September 15, 2009, 10:14:03 pm »
Would be well intrested, could help fill in the gaps of what I can't get if you sold individual parts. Could almost get everything bar a few seals a bearing and strip seals are a bitch to get hold of.
Would be an awesome service!
Online PeteG40
Re: rebuild kits
« Reply #2 on: September 16, 2009, 09:19:10 am »
can sell the parts seperately too - i'll put rough guidline prices up asap
Online PeteG40
Re: rebuild kits
« Reply #3 on: September 16, 2009, 05:55:45 pm »
updated with prices
Offline g40chris
Re: rebuild kits
« Reply #4 on: October 13, 2009, 10:31:40 pm »
very good service idea here. will deffo come in handy
Online PeteG40
Re: rebuild kits
« Reply #5 on: January 09, 2010, 04:53:15 pm »
bump for pics/finalised prices
Offline Fred
  • Fred
Re: rebuild kits - £185 for a full kit
« Reply #6 on: February 06, 2010, 09:27:02 pm »
Will have a Full Kit off you in a Month Pete as i`ve just started work again and need to get other Poohdoo out the way first.
That`ll include the Bolt set as well.
Fred.
Offline Jezza-7
« Reply #7 on: February 06, 2010, 11:23:26 pm »
Pete how much for the zinc plated bolts on there own incl p&p?
James
Online PeteG40
« Reply #8 on: February 07, 2010, 12:34:58 pm »
only a couple of quid for the postage on bolts... full Kits cost about £6.50 to post insured
pete
Offline BrettG40
« Reply #9 on: February 07, 2010, 10:57:57 pm »
Are the bearings particularly hard to remove pete?
Online PeteG40
« Reply #10 on: February 08, 2010, 09:22:54 am »
you need to heat the casings to remove bearings and use a freezer/heat to fit new ones
Online PeteG40
« Reply #11 on: February 23, 2010, 06:40:24 pm »
right have got a few of these in stock now - otherwise it can sometimes be a couple of weeks depending on suppliers
pete
Offline shaung40
« Reply #12 on: February 23, 2010, 08:49:56 pm »
r the chargers easy to do with a little no how neva done 1 before
Online PeteG40
« Reply #13 on: February 23, 2010, 09:02:14 pm »
not too bad... take it slowly and follow instructions i can provide
Online PeteG40
« Reply #14 on: March 26, 2010, 06:25:42 pm »
boo - updated with the bonding agent for the seals.
got full kits in stock now as we speak.  Anyone want one for spring fest, let me know
pete
