charger mounting bushes
Started by camone, September 07, 2009, 07:50:09 PM
camone
Does anyone have any spare charger bushes/spacers that you fit between the chanrger and engine mount before slotting the securing bolts through.
There should be 2 of them, one on top and one on bottom bolt.
If no-one has any could someone give me measurements of the two bits and I can get them made up from solid pipe etc
cheers
chuck
they are normally in your engine mount if yr on about what i think you are.
if you mean the bushes that are normally push fitted into the charger mount then I should have some Chuckles.
camone
Ahhh apologies, I didnt look at it properly, its not the charger that needs the spacer its the alternator. The top long bolt that bolts through the top of the alternator needs a spacer pipe between the right hand side of the alternator and the engine mount bracet to stop it moving sidey ways.
Anyone got one or have dimensions that I can cut from
I think I've got one knocking about in t'garage somewhere, I'll have a look tomorrow chuckles.
camone
