Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Problem with gas fumes
« previous
next »
Pages: [
1
Go Down
Author
Topic: Problem with gas fumes (Read 4838 times)
Alexiskayak_7
on:
May 29, 2008, 11:06:39 am »
My G40 can not pas the gas testing at 2500rpm (it's runing rich) but in idle is great... First of all i've changed the blue temp sensor and i cleaned the injectors...
Is there a possibility 1) The lamda sond is broken?
2)Fuel pressure regulator broken?
3)Co sensor broken?
4)MAP senor?
5)Problem in ECU?
Do you have any idea what may be wrong???
Administrators
Housewives heart throb
Re: Problem with gas fumes
Reply #1 on:
May 29, 2008, 11:17:59 am »
1. is probably the cas
3. set co2 sensor to 550 ohms
Alexiskayak_7
Re: Re: Problem with gas fumes
Reply #2 on:
May 29, 2008, 11:40:59 am »
What is cas???
Administrators
Re: Re: Re: Problem with gas fumes
Reply #3 on:
May 29, 2008, 11:48:34 am »
sorry - probably the case, the problem. (mistyped)
lambda probe can be seen working with an air fuel ratio meter
Alexiskayak_7
Re: Re: Re: Re: Problem with gas fumes
Reply #4 on:
May 31, 2008, 12:43:02 pm »
I've checked with gas analyzer and the λ seems not to be steady at measures (it's going up and down, from 1.06 to 0.963)
Dennis@polo86c.nl
Re: Re: Re: Re: Re: Problem with gas fumes
Reply #5 on:
June 10, 2008, 02:21:57 pm »
Then the lambda seems ok.
It goes up and down around the lambda=1.00 value.
So, lambda value is ok, but CO isn't?
Did you check for air leaks around the inlet manifold?
Last Edit: June 10, 2008, 02:24:39 pm by Dennis@polo86c.nl
GTG40
Re: Re: Re: Re: Re: Re: Problem with gas fumes
Reply #6 on:
June 10, 2008, 02:38:08 pm »
Is the CO sensor on the boost pipe near the throttle body? if so how do u set it to 550ohms?
Administrators
Re: Re: Re: Re: Re: Re: Re: Problem with gas fumes
Reply #7 on:
June 10, 2008, 05:51:18 pm »
yes it is... with a multimeter and by setting the screw on top (it may be under a blue cap)
GTG40
Re: Re: Re: Re: Re: Re: Re: Re: Problem with gas fumes
Reply #8 on:
June 10, 2008, 11:11:58 pm »
[quote pid=1689 author=peteg40 date=1213116678]yes it is... with a multimeter and by setting the screw on top (it may be under a blue cap)[/quote]
Ahh always wondered what that blue thing was
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
