Solid Aluminium pipe from throttle body (psd)
Started by djtez, August 07, 2009, 12:45:59 PM
djtez
the title :D
its needed as part of my Cosworth front mount set up.
You don't have to have that to fit the I/C, could just make up a connector from silicon parts.
if you really wanted a solid pipe then it'd probably be best to find a friendly local fabrication shop and get them to knock something up for you.  Doubt you'll find an old PSD one for sale as they only made a couple as far as I know.
I can't sell you mine because it's been modified to fit with my bigger IC and turbo setup.
djtez
how much modified exactly ?
coz if you were to sell it maby i could make up the rest of the space adapted with samco's?
well it's modified to the point where it wouldn't work.  I cut the end off it and then got a metalworking shop to weld up a different shape of pipe on the end.  I need it anyway.
