G40 saloon
Started by Phil, July 21, 2009, 07:34:38 PM
Phil
Started off like...
Been sat around unloved for a little while as I kept changing my mind on what to put in it :lol: Decided with a stock rebuilt G40 lump with a few painted/powdercoated bits and the usual mods.... GT inlet, G60 injectors, 65mm pulley and an sns map.
Exhaust, thought I'd try maximum angle :lol:
Think I'll be changing that next week though. Engine...
Engine has a few new bits...
Headgasket
TB gaskets
Inlet gasket
Exhaust gaskets
Sump gasket
Camshaft oil seal
Cambelt
Water pump
All rubber o rings
OE Clutch
Plugs
Leads
Dizzy cap
Rotor arm
Coil
Lambda probe
Oil pressure senders
Header tank
G60 front left engine mount, new VW rear and a poly front
Most nuts and bolts replaced with stainless
New charger oil feed
New banjo bolts
Silicone hoses
Spec
G60 250cc injectors
Rebuilt lader
65mm Multi v pullies
SNS anti lag map
GT inlet
4 Branch modified to 2.25" outlet with a straight through 2.25" exhaust
G40 brakes with green stuff pads and ATE discs
Braided hoses
New G40 lower arms
G40 steering damper
Fk highsport coilovers
14" BBS RA powdercoated in shadow chrome with 185 50 14 yokos
Max
breadman
Alright Phil,
That engine bay looks mighty fine. 8)
I do like mk3 saloons - that looks a very tidy example.
When are you due to blow the engine up on it? ;D
try not to break it eh?  ;)
MartinB
Nice one, wheels go really with car and so do orange repeaters!
for no apparent reason I really like the G40 engine bay with the airbox in place, makes it look a bit more complete if you know what i mean?
randombadger69
Good effort Phil, glad to see you got a lump in this in the end. Engine bay looks sweet!
DMWG40
Phil
 :D Cheers. Dont think I'm keeping it too long, and everythings fresh so shouldnt break!
g40chris
supercharged spaniel
love it!  engine looks very nice!
bbspolo
Fired up on the first click aswell!!!
well once u had put some fuel in it anyway!  ;D
Claudio157
raf898
Saw This Car The Other Day When I Picked Up A Downpipe..
Bloodyy Beautiful Bit Of Kitt..
Phil
 :D Cheers. Needs a clean....
