Author Topic: 55amp Alternator  (Read 4577 times)
Offline GTG40
55amp Alternator
« on: July 19, 2009, 05:27:00 pm »
If i was to put a standard (i think its 55amp) alternator on a g40 would it run properly? or does it need a minium of 65amps
thanks
steven
Offline Dan
Re: 55amp Alternator
« Reply #1 on: July 19, 2009, 05:51:13 pm »
I'm pretty sure you would be fine with a 55A alternator. GT's have them and seem fine. 65A would be ideal if you have plenty of interior electrics.
« Reply #2 on: July 19, 2009, 06:00:27 pm »
yoof/hayes i think rock a 55amp on their turbos.
Offline GTG40
« Reply #3 on: July 19, 2009, 08:38:13 pm »
ok cheers
cos i've have a 55amp alt on my G turbo, not managed to get it running properly yet, trying to sus out what up with it. altanator must be ok then if they're running a 55amp. altho my voltage is a bit low.
The problem is it will idle when cold for about 5 mins then it will cut out and won't idle, then i'll start it again then it will idle for about a minute and cut out. sometimes when its warmed up it will idle but its very lumpy, most of the time it just cuts out.
Also if i hold it at a constant 2000rpm the revs will dip every 4-5 seconds to about 1500rpm or lower then back to 2000rpm.
And it seems to be running a bit rich, can smell unburnt fuel.
I've put in 250cc injectors, psd turbo cam and a turbo chip off PPP to suit.
I've noticed if i unplug the blue temp sensor then it will idle fine so i changed the sensor but it made no difference
can any one help
thanks
steven
Offline Dan
« Reply #4 on: July 19, 2009, 09:17:00 pm »
Sounds like you have answered the problem, if the voltage is low it will cause those sort of running probs.
Offline GTG40
« Reply #5 on: July 19, 2009, 09:35:44 pm »
I'll try a different alt an see what happens. funny how it ticks over ok with the temp sensor unplugged
« Reply #6 on: July 19, 2009, 10:10:56 pm »
yes you need to see a good 13v across the battery terminals with a multimeter with all the electrical things turned on or the ecu will get the hump.
Offline GTG40
« Reply #7 on: July 26, 2009, 11:04:56 pm »
getting a proper voltage from the alternator now an does cut out  ;D
managed to stip down the alternator and found 2 wires were broke from the coil to the circuit board soldiered them up and jobs a good'un
