Clearance issues?
Started by djtez, July 12, 2009, 07:31:36 PM
djtez
I have just got my polo started and theres an extremely heavy knockin coming from the toothed belt conversion..
the pulley on the altenator is hitting again the chassis leg... well.. the engine bracket on the leg.
anyone had this issue?
help !  ??? ???
is it a conversion?? the g40 bolt on arb mount has a cut out for this.
pete
yeah I had to make a cut out on mine when I had toothed belts on it.
GSBellew
You can see the notch out of the standard bracket to clear the charger belts.
djtez
thanks guys :)
i also noticed my belt was running to the outer edge of the pulley..
im guessing my altenator is running incorrectly.
im go try either bending the bracket or running a few washed to bring the altenator back in a bit
quiksilver_jake
i thought it was a close one on mine so i took a bit more out also so i could get a toothed belt on with out removing everythin again;)
Nick_S
You can get a bit of extra room by loosening your engine mounts and shoving the engine as far left as it will go.
Dan
You don't want to be bending that bracket, it will ruin your front wheel geometry.
Grind some metal out, around where it's notched.
djtez
i fitted a couple of washers on the altenator at the top on the left to push it across
now it frays the belt ?
lol i'll take one off see how she goes..
no clearance issues with it like that tho..
plus i slackened the engine bracket and two bolts to hte chassis leg..
helped alot!
