Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
G40 stalling/idle problem.
« previous
next »
Pages:
1
2
3
Go Down
Author
Topic: G40 stalling/idle problem. (Read 9457 times)
vwmk3jon
Re: G40 stalling/idle problem.
Reply #15 on:
July 08, 2009, 02:58:10 pm »
Trying to pull away is dodgy to say the least! Its almost like its got a fuel defiency and then suddenly wham, the power picks up. Need them wiping off the chip really.
Nick_S
189.6 bhp @ 8psi boost
Reply #16 on:
July 08, 2009, 03:17:47 pm »
Deffo the map on the chip.
Administrators
Housewives heart throb
Reply #17 on:
July 08, 2009, 03:53:45 pm »
tbh, you'll get a bit of that with the eaton as its all top end power
vwmk3jon
Reply #18 on:
July 08, 2009, 05:27:05 pm »
surely not as bad as mine though? Its like my 1st ever car, the carb would get shit in it and cause me to be stuck at 5mph. thats what it feels like! sometimes i can drive through it, sometimes it stalls.
Administrators
The CV joint killer
Reply #19 on:
July 08, 2009, 07:16:23 pm »
sounds like it's running lean at the bottom end.
Administrators
Reply #20 on:
July 08, 2009, 07:30:38 pm »
1341 g40 eaton i drove was like a gt/stock g40 pulling away, then you got to 4k and it went like stink, only to change and be the same... mind you car was a bag of spanners
Administrators
The CV joint killer
Reply #21 on:
July 08, 2009, 08:09:53 pm »
yeah I wouldn't judge it by that one you had pete, I dread to think what the fuelling on that was like. Seeing as how the "remap" on it seemed to consist of an adjustable fuel pressure reg.
Administrators
Reply #22 on:
July 08, 2009, 08:13:34 pm »
L O L
Administrators
The CV joint killer
Reply #23 on:
July 08, 2009, 08:29:43 pm »
I would say "aint so bad".......but it was.
vwmk3jon
Reply #24 on:
July 08, 2009, 08:31:47 pm »
This pulls away like a stock cube! 5/6mph max!
Traders
Reply #25 on:
July 09, 2009, 08:10:54 am »
Hayesey's car was deffo in need of mapping - yours may be the same. I'd only commit to spending money on a remap once you're 100% sure that everything else is in good health though.
vwmk3jon
Reply #26 on:
July 09, 2009, 12:19:54 pm »
im gonna get the coil changed along with the pulley to a vernier but ive gotta get it working first so i can get the bottom end checked to make sure its not fubared! injectors, plugs, gaskets, sensors are all new.
Traders
Reply #27 on:
July 09, 2009, 02:24:17 pm »
A compression tester should only cost £20-£30, that'll tell you a lot about the bottom end. Did you sort the suspected alternator problem?
cheddarcheese
i like boobs!
Reply #28 on:
July 09, 2009, 04:27:22 pm »
back on topic hijackers
and what's my problem or and possible courses?
vwmk3jon
Reply #29 on:
July 10, 2009, 09:04:56 am »
mine used to be the same. i cleaned the ISV out and checked the CO pot. we adjusted the screw on the t/b too and it ran better.
Pages:
1
2
3
Go Up
« previous
next »
Club G40 Forum
Technical
