Author Topic: 1W bottom end, forged pistons, VAG rebuild parts  (Read 8654 times)
Offline Henry
« on: July 06, 2009, 05:06:39 pm »
Up for sale is a 1w diesel bottom end including:
Crank, block, pistons, rods, oil squirters, flywheel
Custom forged pistons to suit a bore of 77mm and a stroke of 79.1mm, which suits the diesel crank
This creates a 1473cc bottom end
Compression ratio is same as stock G40
I've got an 8P gearbox as well as the over sized Seat Terra radiator (almost new) that could be inlcluded also.
I have about 85% of the rebuild parts (from VAG) including brand new VAG oil pump and water pump
Overall these parts cost me £1300+ - drop me a PM if you're interested and I can answer any questions you might have.
Will obviously need to be picked up due to the size and weight of the bits, I'm based in Cambridge
Henry
Offline Henry
Re: 1W bottom end, forged pistons, VAG rebuild parts
« Reply #1 on: July 13, 2009, 02:18:04 pm »
More info:
Rebuild parts:
Conrod nuts 052 105 427 (x8)
Conrod bolts 052 105 425 A (x8)
Crank bolt N 902 928 02
Main crank cap bolts N 102 638 01(x10)
Oil sump
Oil sump bolt and washer N 902 889 01 + N 013 849 2
Oil sump gaskets - 032 103 609 B
20 X Sump bolts N 900 184 01
Oil pump 030 115 105 E
Oil pump bolt N 010 215 27
Oil pump bolt N 905 293 01 (x2)
Washer N 012 226 5 (x2)
Oil pump bolt N 010 239 11 (x2)
Oil pump bolt N 010 287 3
Oil pump bush 030 115 112 B
Water pump + 'O' Ring - 030 121 005LX + 030 121 043 B
Bosch Distributor cap
Beru Rotor arm
Crank end plate 068 103 171 F
Crankshaft Circular seal 068 103 085 E
BBT H.T Leads
2 X oil filters
Oil breather dome - 030 103 129
Oil pump chain
Bosch fuel filter -450 905 264
Timing belt - 030 109 119A
Both crank plate gaskets 026 103 181 B + 030 103 161 C
Throttle body gasket - 030 133 073A
Water pipe gasket - Water pipe gasket N 902 600 01
BRV gasket - 030 133 074
Exhaust manifold gaskets - 030 253 039A (x2)
Exhaust studs N 044 410 4   (x5)
Exhaust manifold nuts N 900 850 01 (x5)
Head gasket - 030 103 383 AH
5 core plugs
Blue temp sender + 2 clips - 025 906 041 A
Flywheel bolts N 902 061 03 (x6)
Thermostat housing o ring 030 121 119
Water pipe nuts N 901 752 03 (x2)
Offline dub-disaster
« Reply #2 on: July 17, 2009, 12:32:24 pm »
would thins engine be suitable for a g60 charger to be used on it ? and also if a bvh was to be fitted on it would it have to be custom made or would a normal bvh from a g40 fit it??
Also what other parts are involved in fisnishing the engine cost wise ??
« Reply #3 on: July 18, 2009, 04:27:09 pm »
bump
Offline Henry
« Reply #4 on: July 28, 2009, 12:32:25 am »
TTT, if you're interested in just taking the rebuild parts or the pistons and crank on their own, please drop me a message and we can come to some sort of deal.
Offline LeonL
« Reply #5 on: July 28, 2009, 08:14:39 am »
In reguards to just the rebuild parts, what sort of price would you be looking for? What is needed to fill up the 25% you dont have?
Offline Henry
« Reply #6 on: July 28, 2009, 11:04:15 am »
Off the top of my head, the rebuild parts that are still required are the headbolts, inlet manifold gasket and bottom end bearings. I didn't buy standards ones in the hope that I could get some uprated parts from ACL or somewhere similar
Offline LeonL
« Reply #7 on: July 28, 2009, 11:14:31 pm »
and what sort of price are you after....?
Offline Henry
« Reply #8 on: August 13, 2009, 11:34:47 am »
ttt
Offline 6n G40
Offline jez1272gt
« Reply #10 on: August 21, 2009, 12:20:00 pm »
henry ive pm'd you!!!!
Offline bbspolo
« Reply #11 on: August 21, 2009, 01:01:51 pm »
send me a price your looking at aswell mate!
