Author Topic: G40 Starter motor setup  (Read 5253 times)
Offline Tony100
« on: June 27, 2009, 12:38:53 pm »
looking for a picture or diagrams of how the starter wires up??? ???
Re: G40 Starter motor setup
« Reply #1 on: June 27, 2009, 05:40:30 pm »
hot to the top bolt
ground to the bottom
switched wire plug to the spade nearest engine
Offline AdzCM
« Reply #2 on: July 17, 2018, 11:55:01 am »
hot to the top bolt
Can Pete/anyone confirm this please.
Had the engine out and I’m not 100% on  the way this was wired up. The spade closest to the engine is correct from memory but I could have sworn the black negative from the scuttle tray and the red positive to the alternator connected on the top of the starter.. Doesn’t make sense why but, that’s what I remember. There were two nuts on the longer top bolt of the starter. The bottom bolt is short and doesn’t have  enough thread for the negative and a nut.
Adrian
Offline NealPeal
  • Stupid is as stupid does
    • LightDiodeDesignsUK YouTubeChannel (Fun of all sorts)
« Reply #3 on: July 19, 2018, 08:03:53 pm »
On the back of the throw, the bottom leads is the output feed for the solenoid, the bottom the output to the motor...  A bit like this one!
I'd love to know, what's the difference between the two spade terminals? Could one be a buffered input (relay/whatever) explaining my immobiliser over-current?
NEAL :-D
« Last Edit: July 19, 2018, 08:09:57 pm by NealPeal »
Offline AdzCM
« Reply #4 on: July 19, 2018, 09:27:15 pm »
Hi mate,
It’s all good. I realised the black lead I just assumed was a negative is the positive from the battery. The positive for the alternator and it are on the upper bolt of the starter.
I read somewhere what the other spade was for but forgot haha.
Adrian
Offline ereeiz
« Reply #5 on: July 20, 2018, 11:29:08 am »
Check the cable on its run around the sump, they like to go all hard and crusty then snap. Worth replacing if they're worn!
Offline AdzCM
« Reply #6 on: July 21, 2018, 09:20:22 am »
Cheers mate, I’ll have another look today though it felt fine when I was fitting it. Had a protective sheath around it.
Adrian
