G40 Starter motor setup
Started by Tony100, June 27, 2009, 12:38:53 PM
Tony100
looking for a picture or diagrams of how the starter wires up??? ???
hot to the top bolt
ground to the bottom
switched wire plug to the spade nearest engine
AdzCM
Quote from: PeteG40 on June 27, 2009, 05:40:30 PM
hot to the top bolt
Can Pete/anyone confirm this please.
Had the engine out and I'm not 100% on  the way this was wired up. The spade closest to the engine is correct from memory but I could have sworn the black negative from the scuttle tray and the red positive to the alternator connected on the top of the starter.. Doesn't make sense why but, that's what I remember. There were two nuts on the longer top bolt of the starter. The bottom bolt is short and doesn't have  enough thread for the negative and a nut.
Adrian
NealPeal
#3
On the back of the throw, the bottom leads is the output feed for the solenoid, the bottom the output to the motor...  A bit like this one!
I'd love to know, what's the difference between the two spade terminals? Could one be a buffered input (relay/whatever) explaining my immobiliser over-current?
NEAL :-D
AdzCM
Hi mate,
It's all good. I realised the black lead I just assumed was a negative is the positive from the battery. The positive for the alternator and it are on the upper bolt of the starter.
I read somewhere what the other spade was for but forgot haha.
Adrian
ereeiz
Check the cable on its run around the sump, they like to go all hard and crusty then snap. Worth replacing if they're worn!
AdzCM
Cheers mate, I'll have another look today though it felt fine when I was fitting it. Had a protective sheath around it.
Adrian
