Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Electrical
Rad Fan
« previous
next »
Pages: [
1
Go Down
Author
Topic: Rad Fan (Read 3594 times)
ModeC
Rad Fan
on:
June 24, 2009, 11:41:59 pm »
Mine is making some comical noises, i suspect the motor is on the way out. Anybody know whether vdub fitted the same fan to other polo/golfs? I reckon a trip down the breakers is in order.
Cheers!
Administrators
The CV joint killer
Re: Rad Fan
Reply #1 on:
June 25, 2009, 09:52:57 am »
it's a two speed fan on a g40, GTs also have them but I don't think any other models did. I could be wrong though!
ModeC
Re: Rad Fan
Reply #2 on:
June 25, 2009, 02:18:53 pm »
ah bugger that narrows it down a little. hohum if i have to go to the stealers......
Administrators
The CV joint killer
Re: Rad Fan
Reply #3 on:
June 25, 2009, 02:58:07 pm »
probably be cheaper to replace it with an aftermarket slimline fan!
Traders
Re: Rad Fan
Reply #4 on:
June 25, 2009, 04:48:05 pm »
2-speeds were fitted to lesser models too, my CL has one.
Administrators
The CV joint killer
Re: Rad Fan
Reply #5 on:
June 25, 2009, 04:58:42 pm »
I had a feeling that might be the case, hence my initial "I could be wrong" statement
In typical VW of Spain style it'll probably be totally random! You'll be able to tell because a twin speed has a 3 pin connector and a single speed has a two pin one.
Dan
Re: Rad Fan
Reply #6 on:
June 25, 2009, 09:55:30 pm »
It has been know for GT's to come with single speed fans, my blue one did. Like Hayesey said, just look for the 3 pin connector plug and your sorted.
ModeC
Re: Rad Fan
Reply #7 on:
June 25, 2009, 11:21:53 pm »
ah o.k so i will go down the breakers and have a mooch about.
heysey these slimline fans you talk of sounds good have you bought one can you recommend any, I will have to go investigate.
thanks guys for the advice!
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Electrical
Rad Fan
