Author Topic: Oil temp sender - where do I mount it?  (Read 6588 times)
Offline Alex
  • Hack
« on: May 29, 2009, 07:06:52 pm »
I've got oil temperature, oil pressure and boost gauges arriving soon from Stack. :)
I need to find a suitable place to fit the oil temp sender.
Am I right to say these are sometimes fitted inside the sump plug?
What are the alternatives to that? Seems a bit vulnerable to me.
Offline Nick_S
  • 189.6 bhp @ 8psi boost
Re: Oil temp sender - where do I mount it?
« Reply #1 on: May 29, 2009, 07:47:25 pm »
Best place is to get an oil cooler sandwich with an extra threaded 3/8 hole for a temp sender ;)
Offline Alex
  • Hack
« Reply #2 on: May 29, 2009, 08:04:46 pm »
Oh balls, I've just fitted an oil cooler with a thermostat plate.  :(
« Reply #3 on: May 29, 2009, 09:07:26 pm »
I've seen sump plug adaptors for sale on ebay.  Think will possibly do them too.
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #4 on: May 29, 2009, 10:51:56 pm »
i got a sump plug with a temp sender built into the actually plug, you can get them online easily.
Offline Alex
  • Hack
« Reply #5 on: May 29, 2009, 11:20:12 pm »
Are the sump plug ones not a little exposed to damage on a lowered car though?
Offline Dan
« Reply #6 on: May 30, 2009, 10:23:17 am »
Normally not too bad.
ideally, you could get a threaded boss and weld it to the back of the sump. That obviously involves removing the sump. Robins idea should be fine.
Offline Nick_S
« Reply #7 on: May 30, 2009, 02:45:58 pm »
Another way i think i've seen, is to fit another charger oil feed T piece setup on the right hand pressure sender. Screw in a temp sender where the banjo bolt normally goes.
Offline Robin
« Reply #8 on: May 31, 2009, 10:48:03 pm »
road clearance is not a problem as it only sticks out about 5mm more than the normal sump bolt.
Offline Alex
  • Hack
« Reply #9 on: June 01, 2009, 10:10:25 am »
True but that's 5mm closer to the tarmac and a vulnerable part anyway - I may just get a spare sump and drill out a second hole for it.
« Reply #10 on: June 01, 2009, 11:26:50 am »
but you'd need to locate the new hole pretty much on the bottom of the sump anyway or it wont be submerged in oil while the engine is running and will give a next to useless reading.  There might well be over 3 litres of oil in there with the engine off but when it's on the level will go down significantly as some of the oil will be going around the engine.
surely your sump plug isn't the lowest thing sticking down on the car?
Offline Alex
  • Hack
« Reply #11 on: June 01, 2009, 01:11:11 pm »
I dunno, never really looked. But, looking at pics, it's pretty vunerable. Mind you, so is the exhaust and that's never been smacked by anything so I should be fine.
I'm pedantic, you should know that by now. :D
« Reply #12 on: June 01, 2009, 01:38:40 pm »
you'll prob find the subframe sticks down lower than the sump plug by than 5mm, mine does.
Offline Alex
  • Hack
« Reply #13 on: June 01, 2009, 02:38:49 pm »
Hmm, I guess mine's not exactly slammed either which helps.
Offline Dan
« Reply #14 on: June 01, 2009, 05:56:30 pm »
I plan of fitting the oil temp sender on the rear of the sump. due to the angle on the engine it won't be lower than the sump and will be submerged in oil, no problem. just got to make sure you don't poke it into the oil pump pickup !
