Mk3 Polo parts (inc G40) + Emerald ECU + Big valve head
Started by Henry, May 24, 2009, 12:24:10 PM
Henry
Polo NZ throttle body £10
Helix ceramic Paddle clutch 3 piece kit
For sale is a brand new Helix 3 piece ceramic paddle clutch kit. It is all wrapped up in boxes and has never even been near a car.
Clutch for G40.
Costs £338 brand new, closest offer to £300 gets it
Brand new Emerald K3 ECU kit with 3 bar map sensor
For sale is a complete stand alone engine management system from Emerald. I bought this kit directly from Emerald as well as a 3 bar (absolute) map sensor.
It has only ever been taken out of the box once, and that was to take the photos for this advert.
ECU features such as:
Map switching - ECU can store up to 3 seperate maps and user can switch between them on the fly
Exhaust Gas Temperature - reduce boost or add fueling if EGT goes above user set limits
All of the features can be found on the emerald ECU website (http://www.emeraldm3d.com/em_k3.html)
As you can see in the photo, it is a complete kit including:
Invoice for £759.52
Price list for other components
Sticker for inside, Sticker for outside
Large A4 operating manual
PC software on CD-ROM
Serial data cable
Delphi 3 bar map sensor and connector
A4 product guide
Emerald ECU unit
ECU will be sent via recorded and insured delivery methods and will be posted as soon as payment has been received.
£650+12.50 P&P
Polo G40 Big valve head
It has done a maximum of a couple of hundred miles after being converted and operates with no issues.
Brand new Tappets – not been run at all
Brand new oil filler cap
Sand blasted and sprayed rocker cover
Brand new VAG rocker cover gasket
Brand new rocker cover bolt washers, rubbers and caps
All you need is the cam of your choice and some rocker cover bolts and you're good to go.
£600 ONO
Postage can be arranged but the cylinder head is not light and is obviously a little fragile.
Rear strut brace for Mk3 polo
Fits as shown in the photo below, it does fit with the rear seats in place if I remember correctly.
£20+postage
All smiles carbon fibre skuttle tray cover (slight damage)
Bought during a group buy a few of years ago, they didn't come with fittings so these will need to be made up. There is a small amount of damage where it came lose one time and made contact with the window wiper linkage, this is not visible when fitted properly. Please see photos below:
£offers + postage
Schrick camshaft 268/264
As you can see, this is brand new in the box and has never been used. The spec sheet for this camshaft is shown below:
£200 posted
BMW 530D intercooler and BMW E46 3 series intercooler
Both in pretty good condition, end tanks are solid, there are the usual damage to some of the fins but overall very good intercoolers for front mount G40 conversions. The 530D diagram is shown below, followed by a photo of the two intercoolers. In the photo, the 530D intercooler is the silver one at the bottom, the black one is the E46 intercooler.
Core dimensions of the E46 cooler: 540x130x50mm
£45 + postage per intercooler
256mm brake setup for mk3 polo with braided hoses
Had these fitted to my G40 with Raicam pads, and was a much better brake setup than standard. Worth running these with a 22mm master cylinder. Discs and pads not included, postage is heavy so will need to get a quote for final price.
£80 + postage
superchargedpolo
I'll take the rear hoses if they are still available.
PM me some details and I will sort payment out.
Craig
Henry
Raicam brake pads, brakes hoses, strut brace and driveshaft sold!
poloeatonm45
what kind of work has the head had done? just big valves or has i had any porting done
steve
Henry
Yes, both inlet and exhaust ports have had work.
Some pictures:
Henry
Henry
Henry
Big valve head, silver 5 series intercooler and brakes sold
troppo forte
hello henry have you still got the strut brace i an interested in this cheers, forte
The Duck
Hi Henry, Any of these parts still available?
Duck.
LeonL
Old topic, but if intercoolers are still around contact me ;)
Henry
Still got the black intercooler and the carbon scuttle cover, cheers
Gaz_golf_gti
is the 4 branch for sale pal?
also interested in the strut brace
pm me mate
Henry
Sorry, only got the intercooler and scuttle tray cover for sale
